GPS speed on the AVN map screen
nickpike
UK
Hi, anyone know how to get the GPS speed up on the map screen. My Garmin unit displays this, and I find it more useful than the inaccurate (always reads high) speedometer. The HUD speed seems to be the same as the speedo, so presumably that is not GPS sourced.
If not, I will miss that figure.
Nick
Nick
Not sure on the Nav screen display, but my HUD speedometer usually matches the GPS speed on Waze running on my iPhone - so the Genesis speedo seems pretty accurate (at least in my car).
Thanks. You've given me an idea. I'll take the Garmin unit with me and compare the values.
Nick
Nick
I validate with my iPhone gps every time I switch from summer to winter tires. Although my winters are the exact same size as the stockers, the speedo is 2 kmh faster with the winters on. This will also slightly change as the tread wears. Something to double check when you change tires to another brand. Do not assume the same size will actually be the same size, been there done that. ;)
There are tons of free speedometer apps out there. I happen to use this. https://itunes.apple.com/ca/app/speedometer-free-speed-limit/id557871911?mt=8
