GPS Update Fail!
My11Genny
I am pretty tech savy so I tried to update my 2011 Genny sedan with the 2018 cd navigation update from MnSoft on my own. Although MnSoft states this is a dealership job, It really seems pretty straight forward. My dealership sold me the cds for about $150. After some 4 hours and following the directions on Youtube explicitly, the infotainment system firmware update went well but the nav screen keeps cycling. Everything works but the navigation. I get the "navigation system is starting up" for about 25 seconds and then a map or the menu for about 2 seconds, and this keeps repeating. I understand from talking with both MnSoft and the dealership that the cd updates are risky. But I wonder if a simple reboot of the system would clear this loop? I already disconnected the negative battery terminal for several minutes to see if that would do it with no luck. I have been into the engineering menu and seen the reset options but don't know what all the codes are for. I really don't want to invest more to have the dealership spend 5 hours to fix this if there is a better way. I am wondering if I should attempt the software reinstall again or bring it into the dealership? What would you do?
Sggray98
FYI: Not sure all the models affected but the 13.5 Map Update is a total fail on a 2016 Genesis JogDial. It would not update and after working with support, it was determined to have a software install bug (no kidding) and has been referred back to the manufacturer of the head unit. They did offer my money back or wait for the fix. That's the reason it's no longer listed as available on the map website.
My11Genny
Update, today after two previous tries, I was able to get the update to work. I don't know why it took this time because I followed the directions perfectly each time. It took about 6 hours. I honestly can say I will never do this again for 2 reasons, MnSoft stated they will not be providing any more updates for my car, and frankly it is a pain in the ass. We will get a new car at some point and I will be sure to do my research prior to pulling the trigger. I certainly will not be buying anything associated with MnSoft.
EdP
Supporting Member
SUPPORTING MEMBER
5,230
1,986
Parrish, FL
carguy75
340
63
Atlanta, Georgia
The 13.5 update works on 2015 , however I had to use the included black USB drive and the SD card at the same time so it would update per the instructions. Without the USB drive connected the update tap will be grayed out and unusable. I purchased the SD card, so I do not know how it would work with a download only purchase. You may need the USB drive for it to work.
The SD card and black USB drive
Pedal Commander
