Tranquil
- Jun 13, 2021
- Genesis Model Year
- 2021
- Genesis GV80
I have a Prestige,V6 that went through a set of tires at ~15K. I attributed the center tire wear to over inflation as I had run pressures above the factory settings. Replaced them and now, after close inspection, at 23,900 miles my rear tires are severely worn again. The wear pattern is in the center treads, both left and right tires evenly worn. I paid close attention to tire pressure on these tires ensuring 36 psi (cold) on the rear and 33psi (cold) on the front throughout the 8000 miles. My driving habit is very conservative with only moderate acceleration and easy turns. The front tires have very minimal and even, tread wear. Based on the presented evidence, I wonder if my problem transcends the usual tire wear diagnosis protocol. Has anyone had this problem?
