GV80 Soft Jerking Sometimes While Coming To A Stop Or Accelerating Back
raheelbarlas
Genesis GV80
My GV80 2020 2.5T run fine over all on high speeds but when aplying brake as if the car is coming to a stop or when accelerating back sometimes it start soft jerking in between and then goes all smooth again. I have been struggling to understand this problem. It doesnt happen everytime but happens a lot of times when in traffic driving. I have seen a TSB of differential lock nuts which i already tighten from a garage but still this issue is happening. Back shock absorbers are brand new front all ok. No OBD codes showing issues of any trans or engine or any other sort. Its annoying. Can you kindly guide what are the possible reasons? Would be a great help
Please note, I have changed all spark plugs recently, 4 tyres, 4 genuine brake pads replaced recently with discs skimmed, 2 back shock absorbers (original) changed, zero OBD code issues, no bush under the car cracked or in suspensions. 85k km driven
There is a only one very minor leak from the engine oil filter area from the engine body seal side. which i am getting fixed coming Saturday along with 10k km oil change.
Do you think (though the trans oil is life time as per genesis) I should change the trans oil? is that really a transmission problem?
Has someone experience this issue? Its frustrating a bit for such an expensive and luxury car.
