Hi All,
Looking to see if anyone has run across this issue. The car is a 2010 Genesis Sedan 4.6 with Tech package. With HD radio enabled I'll notice after a few days that the volume has gotten significantly quieter at the same numerical volume setting. If I disable HD radio in the radio options and then enable it again, the volume does return to normal only to drop off some time later. This happens with every HD station and is not an issue with HD radio disabled (listening to the same station through conventional radio). The issue does not appear to be related to reception as I'll have a clean static free signal just at a noticeably lower decibel level.
