The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
To those who have had, or have, this problem, I'd ask you all to report this to the NHTSA as well. This issue happened to me again this morning and had it been dark, it could have gotten ugly because I was traveling at 50mph.
Report here:
https://www-odi.nhtsa.dot.gov/VehicleComplaint/index.xhtml
Hi There- 2008 Veracruz. I posted somewhere else on this forum. Dealership has had my vehicle for two weeks and can't repeat the problem. Yet, it happens to me many times a week... when I change lanes and don't snap signal into place with headlights in on position. They refuse to replace the turn signal, even though I've provided them this forum. My case number with Hyundai is 6308849. This isn't some minor electrical issue. My headlights are actually flickering and cutting off for several seconds at a time. I've already reported this to NHTSA. The dealership has run the diagnostics, nothing came up and they can't repeat the problem, so they are releasing the vehicle back to me. It will be $250 to replace the stalk. I guess I will have to pay for it, as I see no other option. Hyundai Corporate states that replacing the stalk will not fix the problem, yet they have no suggestions. Thank you for your time.
That has happened to me with my car trying to find out the problemThe headlights (NOT the DRL's) flash off and back on when using the turn signals. This happens when with using both the right and left signals, switch fully engaged or not. Also, the high beams have flashed when using the turn signals. The headlights have even stayed off for a few seconds before turning back on. Of course, this is intermittent, and did not happen when I had the dealer look at it.
Has anybody else had this issue? I want to head to the dealer with a solution so this does not become more of a hassle than it already is.
Thank you!
I have had that problem. My car is still in the shop for that problem, and they can’t figure out why.The headlights (NOT the DRL's) flash off and back on when using the turn signals. This happens when with using both the right and left signals, switch fully engaged or not. Also, the high beams have flashed when using the turn signals. The headlights have even stayed off for a few seconds before turning back on. Of course, this is intermittent, and did not happen when I had the dealer look at it.
Thank you!
