Help 2010 Genesis Infotainment Screen Won’t Turn Off Key Fob Buttons Don’t Work
Auttyboo94
The infotainment screen will not turn off at all. With the doors locked and the whole vehicle turned off. The keyfoh works for proximity start but not any of the buttons work. I just replaced the batteries to see if I could get it to work, but no. The red light does flash on the key fob whenever you push a button but there’s no response from the car. Pushing the button on the door handle does nothing. If the door is open then the lock switch on the inside locks and then unlocks immediately. I’ve tried turning the key 7-10 times. I have to disconnect the battery terminals just to save the battery from the screen being on constantly. I even waited an hour to see if it would turn off and nope. Also when I manually lock the door the cluster says the key isn’t in the vehicle? PLEASE HELP!
I literally just got this car today.
This is the description of the post from the guy that sold me the car.
“Nice little car put a little bit of money in it new alternator new battery new plugs and coil packs fresh oil change coming out of second into 3rd it shifts a little rough beside that it’s a really nice car book values at $4500 its throwing a camshaft sensor code every once in a while could be the issue it has a 142k on miles I’ll take $2000 need it gone”
You could get the electronic codes scanned at most local auto parts stores. If your vehicle is producing codes, write them down or take a photo of their test results. A YouTube technician determined that some DIYer had installed an extra fuse incorrectly. The electrical diagrams for your car are online somewhere. Try to narrow down each symptom. It will take some time but focus on one problem at a time. If you can't deal with it anymore, many technicians would buy it from you at a low price. Where is the car located?
