Help with trunk light
Jomsond
i have a 2012 Genesis sedan and the trunk light will no turn on. i check the fuse and changed the light. I can not find info on where is the trunk light switch. does anyone know where it is and a part number?
Did you try it with the headlights on? In my old car, the glove box light wouldn't come on unless you had your headlights on. Perhaps your dome light is switched off. Its the one where you can turn on or off the lights when you open the doors.
I always keep the dome light off. but that shouldn't have anything to do with the trunk light .
Like the light inside the trunk or the light on the dash that tells you it's open
