High pitch/humming sounds 62-68mph that goes away after 70mph
yolonge
Cockeysville, MD
Car: 2015 Genesis 5.0 @ 45k miles
Tire: BFGoodrich g-Force COMP-2 A/S @ 12k miles
I have annoying issue of high pitch/humming sound that is not loud. but definitely audible that comes in 3+- 65mph but phases out starting 70mph. Tires are no near to be completed and I do not believe I have alignment issue.
I brought the car to dealer last time and they suspect the tires, but I am concern if the noise comes from other sources (bearings, driveshaft, etc.). It is most annoying that it is so prevalent on normal highway speed but do not want to shell out for new tires just yet. I will probably have the car alignment checked / tire balanced first but wanted to know if other people had the same issue.
I've had similar issues with other cars, one was tires. Check the tires for cupping or unusual wear. Could be a lot of things. I had one car with a transmission whine at some speeds. It still did when I scrapped it with almost 200k on it. See if you can get someone to ride with you and listen out the windows.
Get the driveshaft and the differential replaced; this is the real reason; i have had the same with my g80/2015 3.8L in Dubai and that did the trick.
Tires condition and calibration is a secondary reason for that. Good luck!
