Highly inaccurate digital tire pressure gauge
Van_Nik_75
SUPPORTING MEMBER
138
129
43
Vancouver, BC
I put on my winter tires on my G70 a few days ago and as I always do I check the tire pressure on the tires that get installed that have been sitting in my garage for months. In most cases, the tires need air pumped into them and I have a small air compressor in the garage with a 50ft hose so it's an easy job.
I used to use this analog dial-style air pressure gauge for years and last year bought a digital tire pressure gauge from Amazon because "digital is better", right? The digital gauge also measured in 1/2 found increments so I figured that would also add to the accuracy.
I set the tire pressure on the four winter tires to 36 psi, measuring the pressure with the digital gauge. When I drove to work the next day, I checked the pressure on the dashboard and it showed the pressure at 42 on all tires ! I later checked the same tires with my older gauge and confirmed they were all at 42. The digital gauge said 36. The digital air pressure gauge was 7 lbs off.
pulsar
692
505
93
DFW, TX
I use a regular dial type gage, not the cheap variety but the ones costing about $30 or so and have always found what it says and my tire pressure monitor system have been within 1 PSI or so. I can get you the brand I’m using if you wish? Outside temp changes and as I drive I do see the TPMS change 1 to 3 PSI but I think that is probably normal for PSI to change slightly.
Van_Nik_75
SUPPORTING MEMBER
138
129
43
Vancouver, BC
I'm going to stick with my dial tire gauge shown in the photo as it also seems to be very accurate compared to the TPMS, at least when the outside ambient temperature and inside my garage are fairly close.
Ernie3647
SUPPORTING MEMBER
1,435
497
83
Middletown NY
Mine are set to 36 in front and 39 in rear as per plate recommendation in door. I actually set them to 34 front 37 rear cold now since the cold Temps are here. After about 20 min. Of driving they're at 36 and 39. I use the digital gauge on my Robi battery operated air pump. I've found it to be very accurate. Same as in car display. 18" tires all around.
BadTrainDriver
174
43
Powell, OH
Set the proper pressure cold. Ignore what it reads above the cold pressure once you're driving. Little protip for you.
CVODON
106
43
A regular dial pressure gauge is OK, I have one that is 30+ years old that works fine and use it weekly. The digital gauges regardless of price are cheaply made, most in China and just do not work acceptable. If you want a good high quality tire gauge Summit Racing has some very good ones, Just buy one with the Lowest Scale that will fulfill your needs, IE: Don't buy a 0-100# gauge if your tires take less than 40#.
BadTrainDriver
174
43
Powell, OH
Longacre.
Liquid filled dial gauge.
I leave it in the garage, so it's the same temperature as the tires I'm checking(always cold, first thing in the morning.)
It's spot on, and cost me about $50 10+ years ago.
Alfer
303
63
USA
A gas station by the house installed a fancy digital air compressor that I use now since you just set the pressure you want and fill up tire until it stops. Been pretty accurate.
GarnetTy1473
316
63
Noblesville, IN
Genesis G90
Always going analog. I tried a $150 digital one on my son's race car, and it was terrible. Went right back to the old analog style.
3.3 Rulz
85
Las Vegas, NV
No Genesis Yet!
Same story here, I've always had a regular, round tire gauge and it was always accurate, then I bought a digital one at Walmart, and it was off by 5+ psi, so in the trash it went.
Husky
847
93
Lots of good points (and opinions) made in this thread. Maybe this will become the new "which oil is best" thread, haha.
WhoIsHomer
57
Edmonton
I find its best to just put the spout in your mouth and use your tongue to push the valve in, it gives you a better feel for the pressure. Always worked well for me.
