Homelink not pair with chamberlain garage
hjf0416
I got a used 2024 gv70 yesterday and trying to pair homelink with my chamberlain garage opener. I followed every single steps from manual, youtube video, but still not working. Here are the steps I was doing
1. push the homelink button, got the orange light on
2. Hold garage remote until homelink turns to a SOLID green. This is where I find weird because manual said light should turn flashing green for a rolling code garage, solid green means it's paired successfully and should just work. (I'm pretty sure mine is rolling code)
3. pressed the "learn" button at the garage motor , went back to my car, hold homelink button 2 seconds before release, repeated a couple times. But still not working.
I wonder what I did wrong, I suspect this is because somehow homelink consider my garage door as plain code garage and not proceed to the second "learn" phase.
Try this. Unplug your garage opener for 30 seconds and plug it back in. Then, completely erase the Homelink memory by holding the outer two buttons until the light flashes. Start the process over from the beginning. Sometimes the opener just needs a reset to accept the new signal.
Take a look at the opener. Does it have a "learn" button? Some do. You push the learn button and then you have 30 seconds to push the button on the mirror until it flashes.
