How do I access behind the DVD
marinakorp
King of Prussia, PA
Hi,
I have a 2011 4.6 ... tried the Blue Tooth Dongle for the phone...hated the sound.... so I want to re-locate (sort of) the IPOD connections... or at least extend them to where I want them... which is near the cigareete lighter, or behind the wood / plastic cover of sorts.
I already "tested" this bu adding a USB extender cable to the USB port... and a 3.5mm extender to the Aux... and then connected the Cable to the extended portions... works great.
What I want to do is run the cables along side the shift console area (can tuck from under neath, no problem) ... but I would like the cable to come out of the dash... right above the sliding area for the cigarette lighter... and below the faschia for the DVD panel...
My Cell phone mounts in the DVD slot (never use the DVD) and want the power / cable to be "right there" above the shifter when in park.
Hope this makes sense.
Any instructions on how to get access to this area... or to remove the side covers from the shift console / front area near the glove box... that might give me enough access I think.
Hope this helps.
Yes. Thank you. What is holding the "wood" in place?
Looks like it just pops right off?
