How do I delete music on the jukebox?
Kyser_Soze
Missoula, Montana
I've looked in my manual and a downloaded manual and tried every button in the car I could think of, but I can't find any way to delete songs I've placed on the jukebox. Does anybody know how? Thanks in advance!
I don't have the ability to write it all out (time constraint), but it can be done. I erased some songs that were on my CPO purchase.
Maybe search the forums here as I believe I have seen it covered.
I did a search for "delete music" before posting and didn't see anything relevant.
They probably delete (one by one) while the tune is playing.
Hi Kyser, I found the following to add music:
If you watch to the part where he accesses the uploaded music files (around the 3:25 mark), I would think each folder/song could be selected and you should get a window asking if you want to delete. Seems straightforward, but can't vouch yet; will try it this evening on mine.
My question is what buttons do I push to bring up the option to delete either songs or folders. I bought my car used and I may be missing the separate manual. I d/l the 2015 manual and it doesn't mention how to delete files.
Hold your finger down on the file or folder (long-press) and that should ask you what to do next (Delete? Yes/No). If you have the Jog Dial, you should be able to step through the files and click (press) which should give the same result.
Hi Kyser, I found the following to add music: ....
After watching the video, I took my cell phone out to my car to video the button presses I get when I press menu (no delete option shows up!) but while I was navigating between folder and songs my phone rang and I took the call through my car. After I hung up and pressed the menu button, the very first thing that came up was the folder view and "Delete All" was an option. So I was able to delete all but I was no longer taking a video. I guess next time I need to delete songs, I'll have someone call me! Thanks to everyone.
I tried a long press and nothing happened. Maybe not long enough? The long press seemed like a logical way to bring up an option menu.
Yes, odd but sounds as though you're doing it correctly. I will check mine when I get home later and advise if I find out anything notable, as I can't see it being any more complicated than that.
Hi Kyser, I figured it out. Uploaded some music from a drive and, like you, couldn't get it to delete with a long-press or anything. Then finally, almost by accident, while a song is selected I hit the 'Menu' button, which then brings up a side menu that asks to Delete, Delete All, Etc. Upon hitting Delete, it lists your songs with checkboxes on the right to select and pick. Then hit Delete and bye-bye birdie lol. Wow, you'd think they'd tell you that somewhere. o_O Anyway, give it a shot.
Starting with the suggestions found in the forum, I played with it until I worked out the following method to delete individual songs from the Jukebox.
It won’t let you delete a song that is playing, so pause before beginning
Select Jukebox
Select List
Select Songs
Select Menu
Select Delete
There will be a list of the songs with a box to the right of each song. Press the box for each song you want to delete - a check mark appears in the selected box
Then press Delete from the menu
I would have been great if Hyundai had put this in the Genesis manual!!
Yes
I figured it out. Go to jukebox, then hit menu, select sound options and then clear jukebox
