How to access headlight bulbs?
HID bulbs? Mine are anything but yellowish.
The HIDs on the car (stock) are color spectrum 4300k (with a hint of amber/yellow). I'm changing to 6000k for a true "white/daylight" color. I have changed all my other vehicles to 6000k and can definitely see better at night time driving. I also prefer the white instead of yellowish tint color output.
Interesting - I would love to see the difference. I have had some good headlights in the past and find the Genesis' to be quite good.
Are you sure you can see better? 6000K doesn't nearly put out as much light as 4300K, and the human eye doesn't react well with the higher color temps such as 6000K. The result is the illusion that you can see better than you actually can, and that's not safe.
Color Temperature is a real measure, but it is being improperly used to claim improved seeing. Legitimate bulb manufacturers do catalog the color temperature of their products in technical literature not usually distributed to consumers, because scientists and engineers can use it as a convenient proxy indicator for filament luminance. But it has no predictive value for the performance of an automotive headlamp, nor does it indicate how well you'll be able to see. The idea being sold with these "Kelvin ratings" is that the light is closer to natural sunlight. As with many sales claims, there is a small kernel of truth here, but it's cancelled out by the smoke and mirrors. Noonday sunlight does have a much higher color temperature than most uncoated headlamp bulbs, but there are a great many other differences between sunlight and headlamp light, as well. Not only that, but the Color Temperature rating is really valid only at extremely high light intensity, such as that produced by the sun. At the lower intensities produced by most electric lamps including headlamps, the rating no longer says much about the light, but only allows a limited, referential comparison of different light colors
http://www.danielsternlighting.com/tech/bulbs/superwhite/superwhite.html
4300K puts out more lumens than 5000K (pure white) or 6000K (very slight hint of blue) however perceptively 5000K and 6000K look brighter than 4300K when viewed head on and when reflected off materials since they are closer to daylight. The lumen difference is not really all that great from a practical standpoint since your lights are still putting out way more light than a halogen-equipped car but you do lose some light output and in some circumstances like fog or heavy snow the reflectivity of the 5/6 bulbs can be a nuisance.
4300K = 3200 lumens
5000K = 3000 lumens
6000K = 2800 lumens
Halogen = 1400 lumens
I've ran a 6000K Philips kit in my last car as HIDs were not an option and loved the look and the visibility was excellent but that car did not have HIDs stock.
Best I can tell, getting at the bulbs is not intended to be a user activity. I looked as I liked the crystal white look but not enough to start unscrewing stuff to get to the bulbs. May revisit it down the line. I will pay good money to get rid of the yellow DRLs.
4300K = 3200 lumens
5000K = 3000 lumens
6000K = 2800 lumens
V-leds.com has V3 Triton bulbs that will replace the yellow DRL's. There is another post on it here http://genesisowners.com/hyundai-genesis-forum/showthread.php?t=13974 They are SWITCHBACKS, which mean they run white but change to yellow when turn signals are on.
Once I you go 6000k you cannot go back to 4300k!!!!
What bulb is this? 09 sedan tech package thanks!
V-leds.com has V3 Triton bulbs that will replace the yellow DRL's. There is another post on it here Solution! LED DRL's and LED turn signals They are SWITCHBACKS, which mean they run white but change to yellow when turn signals are on.
Does the switchback drl/turn signal bulbs really work on the 2015 genesis, as a direct plug & play replacement, or you have to do a modification and rewire. ?
