Yea, initially I looked at this and said, "WTF?" But I have been doing my own wrenching since oh, 1973, so this is how I approached it.
Assumptions:
1) Plugs SHOULD be a fairly straightforward procedure.
2) It should not take ANY "special" tools (Hyundai only, that is).
3) It is a moneymaker for the dealer (because they will 'recommend' this procedure to an owner at some time or another, as they did for me as 'routine' maintenance).
Once I assumed that (and I don't always like to assume things), I started looking at it and identified the hold-down bolts and nuts. It wasn't too hard, then, to identify the other items that needed to be loosened and moved to get the plenum out of the way.
Could a novice or beginner do this? Probably - however, I did put in that caveat about the possibility of LOSING the two REAR 10mm bolts down the back of the engine. These 10mm bolts also have a hex 'hole' in the head as well. I initially thought the only way to remove them was with ratchet and hex ("Allen" wrench). Anyways, the two rear bolts DO affix the rear of the plenum, but NOT into the manifold..there are a couple of ears, or 'tabs' that are sleeved and threaded that stick up off the back of the manifold. So the holes these bolts go down into isn't as much of a 'captive' space (by captive I mean that if you drop the bolt down in the hole, the bolt will either fall into it's treaded socket there or just sit in there, where you can retrieve it) as it is just an "open space" under the plenum. If you attempt to retrieve the bolts after loosening them, without a magnet or a glob of grease in your 10mm socket), the bolt can easily drop off that little 'platform' and disappear into Hades, never to be seen again. THe first one I removed, I dropped, and luckily, LUCKILY it landed in a place where I could use my picker to get it (with a flashlight and mirror). Didn't repeat that problem again. Anyways, yea, it would be a 2-3 hr job for a novice - if the proper procedures are observed, and care is taken not to lose a bolt or two, and the proper torque specs are used.
Q
