How to: Changing the key fob battery (Video)
Thread starter #4
PMCErnie
80
48
Richmond, VA
Re: Changing the key fob battery
Too bad you didn't read this thread first. You could have done it yourself and had money left over for Starbucks.
Mark_888
122
63
True enough but I would rather pay the little bit and not scrape, break or mess it up at this point.
Still got a Starbuck, tall, black, regular. No fancy froths for me.
Earl
Using a screwdriver to pry it open can deform the plastic seams a little bit, but a little sandpaper makes it like new again.
kn5owa
Sustaining Member
1,206
7
38
Pull the key out halfway & rotate to open fob shell - no fuss - no muss
See the video in the first post
inisfree
Video worked great, glad I found it here. Thanks for taking the time to post! Regards, Inis
2012 Genesis, 4.6 L V8
landtuna
6
Sandstorm, AZ
The trick is to remove the key first.
http://youtu.be/uC7iIa6vwAU
DO NOT use this video to change battery. You will break off a tab. Instead, get a small straight blade screwdriver about as wide as the slot near the key hole. Place screwdriver in the slot and twist. Much easier and without risk of breaking the plastic.
