I will preface this by saying I am nothing more than a shade tree mechanic, and I accept no responsibility for anything that happens based on this post, but I recently accidentally found a possible trick/diy fix for the e brake screaming/not working issue, and all the lights coming on the dash, like hold, e brake etc, etc. When I took the rear rotors off, the e brake shoes were disintegrated. Like a pile of dust on the inside of the rotors. Just the metal plates were left. I replaced the shoes (like 40 bucks and a severe case of drum brake spring frustration). Then, with the rotors off and shoes not connected, I pressed e brake button. I could see the cable going in and out, module screaming like a banshee all the way. It would only do this 3 or 4 times and then stop and the lights would come on the dash. Problem was, it always stopped the the cable retracted, ie brake on.Then, I literally timed it, and unhooked the battery when the cable was all the way out, brake completely off. I left the adjustment tensioners all the way closed too and put everything back together and left it unplugged overnight. Next day, I hooked up battery, lights were off and I went on my merry way, knowing the brake was completely off. I was scared to press the button, knowing that it could lock me up completely and having to beat the rotors off or cut the cables. I found the module with cables in AZ salvage yard and had it shipped to me for ~$200.00. (Better than $2400 from the dealership). Once it arrived, I said, I’m gonna press the button, and see what happens. If I get locked up, at least I’m in the garage, I’ll cut cables and tie them up somewhere until I find someone to install the new module. You can imagine my dismay and jubilation. It works perfectly. No screaming, it doesn’t even make the noise it made back when it did work, I can barely hear it. Holding good too. No lights on dash. Running around my garage yelling “It verks, it verks!!!” (Insert fake German accent). Probably scared the neighbors, but this was a miracle. (If this doesn’t work for you, part number is 59700-3M900). Do NOT pay the dealer price. These things are available from salvage yards. If it does work for you (or you have questions), bell me, I’m wanting to know if this is a fix or did I just get lucky.
