How to get pull end of EPB module cables further out?
corneliusw
Any suggestions on how to get more slack on this part? The end cord to the EPB module? As I need it to pull out a little bit more for reassembly of brake pads.
Use a scan tool that has the EPB function to release tension on the parking brake cable, and afterwards to re-initialize it.
I did not have to adjust my EPB for my rear pad or rotor removal. I believe I just used the parking brake button to manually disengage the parking brakes and installed the rotors and pads.
Correction: I see that you probably talking about the rear parking brake shoes(pads). I have no idea on how to just loosen the parking brake cable.
This may help.
Would that be the actuator control- release and actuator control- apply under electronic parking brake control module for a scanner? Having a hard time finding a scanner and the one I did for Hyundai just shows actuator control for EPB. As I did that release and it did nothing, unless I am suppose to tug at hard by hand.
I would have thought that EPB actuator release would do it.
I think that those just two apply and release the parking brake.
Yeah, it's not loosen the end of the cable at all with that function.
Is there a way to manually loosen it so that I can have it extend out further if I opened the EPB module? As access to that is easy and fast.
