diamondmit
- Oct 31, 2015
This one is really easy.
I had a seatback that wasn't properly, uh, seated. It could be easily pulled away from the bulkhead between the passenger compartment and the trunk. I assume it was an assembly error, so....
1. Move the driver and passenger seat fully forward
2. Look between the seam between the seat bottom and the seat back
3. Locate the seatbelt buckle and move your hands 3" away from the buckle towards each side door....now pull this seam apart and you will see a 12mm bolt and washer holding what looks like looped metal beneath it.
4. Remove this bolt (one per side). Don't move the cushion around....there are wires attached.
5. Pull up sharply on the front of the bottom seat cushion (where the back of your knees would be if you were a passenger in the car)
6. Find the wire connector release (a push-down tab) and disconnect the right and left side seat heaters (2 connectors)
7. Remove the lower seat cushion entirely from the vehicle. It's light - one person can do it.
8. Now you will be able to see (4) 12mm bolts and washers at the base of the seatback. Remove all 4 of these bolts (they too hold down looped metal tabs, just like the seat bottom).
9. To remove the seatback, you will have to lift the entire seatback straight up while pulling the base of the seatback away from the bulkhead by about 6 inches. Once the seat releases, you'll see why. On the right and left, there is a plastic recess mounted to the bulkhead, that accepts metal tabs from the seatback; near the center of the car, there are two angled clips that grab metal bars on the seatback. The angle means that you have to pull the seatback bottom away a little bit if you hope to release the seatback.
10. At this point, I stopped because I achieved what I needed to achieve, but you can disconnect the airbag wires on the seatback if you want to take that out of the car too. I may revisit this in pursuit of additional base from the audio system but that is for a later day.
Good luck with your car mods.
David
David
