How to remove Sirius XM Preview (Ad)
Korean power
Every time I get into my 2016 3.8 premium it goes directly to the Sirius Xm preview, trying to get me to subscribe. I do not want Sirius xm I only ever use my iPhone for music. Is there a way to delete the Preview so when I get into my car I don’t have to listen to a commercial before being able to connect my phone.
Would it be worth paying for the update to get Apple car play? Would be nice to use for navigation.
Side note: It has recently gotten cold in Pa where I live both rear tire pressure sensors are going off, but all four wheels will have the same tire pressure. I know this is common in a lot of cars but worth asking if there’s a fix!
What is the car set for on the radio? It should be going back to last set so if you had it on an FM it would go back to that. Not sure when the last setting was other media though. It may default to XM. Just for fun, when you disconnect next time hit the AM/FM button and see if that does it, though would be nice not to have to.
How far off is the tire pressure when cold? Even though they read the same it could just be marginal tolerance on the sensors and even a half pound can trip them. It is a common problem with all cars when there is the first cold night of the year, usually solved by bumping up a couple of pounds for the winter.
The tire pressure it never off by more then 1, will try giving it a little air hopefully should do the trick.
Is the Apple
I normally turn off the car before disconnecting so most likely goes by default. Is the Apple car play update worth it? Does it completely update the whole software or is it like an app I go to? If the update would divert me from listening to the Sirius Xm preview and allow me to use navigation a lot easier may be worth the money in the near future.
The tire pressure is never off by more then 1, I’ll give it a little air should do the trick.
Have you ever had any experience with Car Sense? I got the car transferred to my local Car Sense and I honestly feel like they didn’t look over much before selling it to me. All the tires were unbalanced, had the common headlight glitch problem which took months of me going back and fourth between car sense and Ciocca Hyundai. Finnally got it replaced when I had to make a complaint to Hyundai Corporate and send videos of the problem showing it was a safety risk. The service at car sense hasn’t been the very best, I’m still under dealer warranty, and bought an extended warranty from Car sense due to all the electrical components in the car.
Is the Apple
I bought my 2016 hyundai 3.8l sedan from Car Sense In Hatfield, PA. They have been great to me. Post purchase, two new tires and front rotors and pads last month. Bought the car this past april.
Is the Apple
Are you saying the pressures on the display aren't off from each other more than 1, or none of the tires vary more than 1 from the stock pressures? I think the TPMS light on my '15 5.0 is triggered by a 5psi low condition, so for the fronts that's 28, for the rears, it's 30... It will absolutely not illuminate because the tire pressures are different between each tire.
