How to tell if G6DA?
jmp2012sedan
How can I tell if the 3.8 in my 2012 sedan is the G6DA engine or not?
Have you tried a VIN decoder like the one linked below? It might ID the engine.
Per Wikipedia:
3.8L (G6DJ/G6DN)[edit]​
The 3.8 L (3,778 cc) version compression ratio is 11.5:1 and power output varies depending on configuration.
It produces:
  • 334–338 PS (246–249 kW; 329–333 hp) at 6,400 rpm and 40.3 kg⋅m (395 N⋅m; 291 lb⋅ft) of torque at 5,100 rpm for the 2011–2014 Genesis Sedan and Hyundai Equus.
  • 350–353 PS (257–260 kW; 345–348 hp) at 6,400 rpm and 40.8 kg⋅m (400 N⋅m; 295 lb⋅ft) of torque at 5,300 rpm for the Genesis Coupe
  • 315 PS (232 kW; 311 hp) at 6,000 rpm and 40.5 kg⋅m (397 N⋅m; 293 lb⋅ft) of torque at 5,000 rpm for the 2013–2020 Genesis Sedan/Genesis G80 and Genesis G90.
Applications:
