Hydraulic Trunk Lift(s) ?
surprisinguy
NC
Good day, anyone know if the 2015 Genesis has one or 2 hydraulic lift tubes in the trunk area? This is not the motorized version. I've seen people replacing one of them but was wondering if it had one on each side or not.
Thanks!
There’s one on each side but only need to replace one side if you’re updating to the stiffer one.
This is the original part number: 81771-B1000 - what would be the "stiffer one" to order?
Thanks
I bought two used ones. If you only want one, You can buy my other one. Part # 81771B1010
81771B1010 - so that's the stiffer one? Did you only install one and it worked ok?
Yeah that’s the stiffer one. Trust me, you don’t want to replace both. I can barely close it with one arm in one swing. I only have the right side installed, works great.
