I have a 2016 Genesis Sedan 3.8 recently had oil change
Angelm
Now my oil light comes on and off. How to reset oil change as it seems to be on a timer for oil change
Use the button the steering wheel to find it in the settings. Maybe someone has a more precise instruction, but it is there, buried.
The low/no oil pressure light has nothing at all to do with the oil change interval. Your oil pressure sensor is probably failing, a common issue. Unfortunately, it usually leaks when it fails and can ruin the wiring harness.
