How do you know it's the ignition module? IPMs are not a common failure point on our cars.
Missing hood switch rubber bumbers is, however, the single most common source of battery drain on unmodified cars in my experience
battery draining when car in garage, is a parasidic draw my problem?
my car has gone through 3 batteries in as many years. I took a reading on amps while sitting in garage and it was 2.85. does anyone out there know what is normal for my 2009 sedan. I also own a 08 santa fe and likewise took an amp reading of 1.35 while in the garage. Maybe my easiest solution...genesisowners.com
Actually just a matter of "guessing" by trying to narrow down the draw on the battery when the ignition is off. The brand new battery I put in was dead over the weekend for the second time in a month. When the ignition is off I tested the fuses and there were about 7 of them still drawing power as well as a 40 amp mystery fuse that is labeled "spare". I made sure that nothing was "on" inside the car at the time. (radio, a/c etc.) This all leads me to think it's the ignition relay not switching some accessories off when it should.How do you know it's the ignition module? IPMs are not a common failure point on our cars.
