Ignition Switch Functioning
kn5owa
Sustaining Member
If the ignition switch is left in the "On" position without the engine running - as when doing service work - will it eventually revert to the "off" position automatically?
Or, can one expect a dead battery or a damaged ignition system when it is accidentally left on?
I know that with the car ignition left on "accessory" it will time out and shut off after a considerable amount of time. Found this out at the drive-in theatre where you use your car's audio system to hear the movie. Took over an hour if I recall.
Ignition system damage went away with the old coil, ballast, and points ignition. That was in the early 80's I think.
