ctrcbob
CTRC, USN Ret.
- Jan 11, 2009
- Genesis G80
Had to clean out the trunk as I am getting ready to take another trip, this time up to Penfield, NY and then to Lake George, NY. Removed all "stuff" and stowed them in two bags, (one for things I use often, and the other for "stuff" that I seldom use, but nice to have when needed.
1. Removed the trunk liner and washed it off with soap and water.
2. Lifted the trunk cover. What a great idea. There is a plastic "hook" that clips into a holder in the bottom of the cover. Unsnap the hook from the clip, then place the hook on the upper edge of trunk. This holds the cover open. (I just love that the hook has its own snap in place when not in use).
3. Love that the battery in trunk has its own vent tube, that vents out through the bottom of trunk.
4. They even thought of adding a foam spacer on the bottom of the cover, that lays on top of the battery, to keep the cover from falling down into the battery.
5. Took spare and jack out, just to see how they are stowed, and how they work, if ever needed.
Closed everything up, placed trunk liner back in place.
One question though. What is the purpose of the square metal "D-Ring" on each side of the inside of the trunk? Only thing I can figure is that you can strap things between the two rings. Other than that, I have no idea.
