Car dvd player installation is a Professional work,Install an indash car dvd player is not simple and easy,we recommemd all of the customer take the car dvd player to install by a Professional Technician who has experience in this work,or sometimes there will be problem in installation.Here is the simple instruction for car dvd player installation:
Installing a permanent DVD player takes a few hours, and you will have to use some basic tools. Start by removing your existing car stereo, including the dash fascia and trim.
Detach the existing car stereo unit from its mounting brackets and wiring harness.
Consult your DVD player's owner's manual to see if the new DVD player head unit requires different mounting brackets than the ones that fit your old stereo. If you have to mount new brackets, remove the old ones first and set them aside.
If you wish to install a DVD changer in the trunk or under a seat, you will have to run the power and auxiliary audio and video cables to your stereo head unit before mounting the new head unit and finishing installation.
After reattaching the wiring harness, secure the DVD player to the mounting brackets in the dash. Make sure the DVD player works before reattaching the dashboard trim and fascia.
Finally,please take the car dvd player to install by a Professional Technician,espcially for the model which has can bus,and it is very important if you want to install a backup camera ,please ready the instruction for installation of the rear camera carefully before connecting the wires.
