Install SUB into 2022 G70 base
ToshMac
Hey y’all.
New to the G70 family.
What is the best way to install a sub into a 2022 g70 base. Thanks for your help!
Do I even have a factory amp? Do I also need to install an amp as well?
Depending which sound system you have, there are already two subs under the front seats. The cross over is fairly low so with some songs they are difficult to hear all the time. Yes there is an amp hidden under the trunk panels again depending which sound system you got, the plain stock or the upgraded system you get with higher trim levels. There are threads here already on sub installations you might want to check out what some have already done.
