Installed 10" Sub
Dassat
Just installed 10" Infinity single voice coil 4ohm sub and a kenwood mono 300watt RMS, 1000w peak amp. I tied into the rear sub speaker wires for the feed and left the stock sub active.
Pretty pleased with the outcome. I didn't want ground shaking bass and I think the single 10" is perfect and compliments the system pretty well. Hits harder and gives a lot more depth. I have the gain about halfway and has a lot more to give but think it would be too much if I turned it up.
Interesting observation is that if you open up and get in the trunk it is very loud, but when you close the trunk I can barely hear the whole system. The car is insulated so well.
Another thing I found is that I think the green wire on the sub is actually negative. I wired the green as positive initially but sounded like the phase was off.
Have you tried to open the passage way into the trunk from the rear seat? Should help direct some more sound waves into the main cabin.
I did. Doesn't make too much of a difference. I don't feel that I need to though. Plenty of bass with the armrest up.
Any pictures? I would like to do something like this yet, I am very concern that I may mess something up. Thanks.
