IOS 26 and "Shifting" Map in CarPlay, and Blank map on Dash
checkyourmirrors
Genesis GV60
Since upgrading to IOS 26 I've notified a couple of problems that have popped up with CarPlay. The first is when stopped, the Apple map will shifting slightly up and down, over and over and once I start moving it stops. The second is sometimes the apple map on my Dashboard stays blank white, and the map on my middle display is in turn by turn mode versus the typical total route overview.
I hadn't seen anything about either one of these and curious if anyone has seen the same?
Not a lot of feedback on this which makes me wonder if I am the only way with strange CarPlay behavior. Now the apple map isn't showing up on my dash behind the steering wheel. It was either showing up, or it would be blank where the map is supposed to be. Now I have the Genesis map showing up with CarPlay only on my center display....
Have you upgraded to iOS 26.1 at this point?
Yup, and after 26.1 the map disappeared from the drivers display
