It is a good quality synthetic oil with dye. That's it. Same as other high quality synthetics from Mobil 1, Pennzoil, Castrol, etc.I have used it from my first oil change moving forward.
I also use it on my modified Sky.
I would read analysis reports before believing that it is just purple dye.
I don't suggest using Royal Purple in turbocharged cars. In engines that run hotter the stuff is known to shear down. If it gets too thin, you could end up with bearing damage.
I used to run RP in my Z06, one I tracked pretty heavily. Never had a single issue with it. Also ran the RP in the trans and rear diff. It's good stuff. I don't think even how I drive my R-Spec (see earlier comment about being a track rat) that I run it hard enough to need it over Mobil-1 from Costco on sale, so I just use that. I'd happily go back to RP, though.
You can buy Mobil 1 EP and put some purple dye in it, and you will have a superior and less expensive product than RP.Makes sense. I may also switch over to Mobil-1 EP just to save money. My Genny is a DD and will never ever put it on a track. Rarely do I do any "spirited" driving, and on the rare occasion that I do, it's for very short bursts. But, I do like my RP.
Thanks for the clarification.
