Is Dynamat needed
Nightowl805
Has anyone felt the need to add Dynamat to the doors and/or trunk? I have heard multiple comments about the stereo and it seems that a sub may be the only thing needed though that is user dependent.
If I put in a sub I have thought about Dynamat for the trunk and maybe doors but wonder if that is overkill for this car.
Unless you plan on going with something drastic, it's not necessary IMO. It always helps of course, but with a single sub you should be fine without. Just place some barriers in the vibration prone areas (license plate/gas cover) and you should be good to go.
If you plan on building a setup in the trunk well (spare tire), then I would dynamat that area.
Search this forum for simplicityinsound for his reviews.
His build thread (minus all the unnecessary back and forth) can be found here:
http://www.diymobileaudio.com/forum...-2012-genesis-sedan-600-pics.html#post1660547
Good stuff; well worth the read!
