Issue with car not starting
Khmai323
Does it sound like a starter issue or something to do with the fuel system?
It sounds like it is getting very little fuel.
Do you think it could be a fuel pump issue or a fuel injector issue?
It would probably have to be over half the injectors, so probably not that. Yes, it could a fuel pump. It could also be any sensor issue that might make the PCM think that it should only inject a tiny bit of fuel, for instance if it thought no air was going into the engine.
I think that you need a good enough scan tool that you can graph things such as how much fuel the PCM thinks it is injecting when the starter is running, how much airflow it sees, and so on.
