Launch Control
Toddasaurus
Robots, lasers, dinosaurs.
831
673
93
Portland, OR
You might be right, the ratios are different: 2019 Genesis G70: Equipped To Compete
2018 Kia Stinger Specifications
The Kia has the higher (lower? Gearing confuses me) ratios, putting more power down right away from what I can tell
Make sure you compare the same engine. According to both sources you posted the gear ratios are identical (ie 3.3tt 8spd).
Unsure of why their testing showed the G70 as being slower than the Stinger. I think they should line them up together and do a head to head. The G70 should be a faster car than the Stinger in every way.
joschneider
199
43
Las Vegas, NV
thank you for catching that, totally missed that dropdown. so the gearing is almost the same, close enough. youre right, a head to head dig/from a roll is what we need. also, someone needs to get on a dyno asap :p
BlancaGenny
AUTHORIZED VENDOR
452
94
Rapid City
canucklehead604
one of the few 6MTs...
481
231
43
West Coast Canada
^ huh? gearing is identical between G70 & Stinger, regardless of engine. this is part of the arguments that several forum members have made supporting why the G70 'should' be quicker than the Stinger. same engine + gearing - less weight = quicker. to date, none of the testing has shown this which has us confounded. we need a back-to-back test under the same conditions.
joschneider
199
43
Las Vegas, NV
Yes and Todd corrected me on this yesterday if you scrolled up (y)
tx_boy
9
No Genesis Yet!
I’m almost at 1k miles. I’ll get the JB4 late March or early April. Unless this winter is super mild...which I’ll get it earlier.
I would stick with Lap3 when it comes to these cars. They have been tuning them for years now while JB4 is not even a year in. Not to mention one Stinger running JB4 already put a rod through their block. Not saying it was the piggyback but he wasn't even FBO. Have not heard of anyone running a Lap3 tune or piggyback pop an engine. Good luck and I can't wait to get me a G70.
Oh and they already are swapping the turbos in Korea and pushing 600+WHP in Korea on the Stinger.
dareckibmw
Supporting Member
SUPPORTING MEMBER
2,112
369
83
Romeoville, IL
Genesis G80 Sport
Toddasaurus
831
673
93
Portland, OR
Do you have any links so I can read up on this? I've been waiting for a viable turbo upgrade for the 3.3tt - I'm curious what turbos people are beginning to run! Cool to hear about. Thanks for that.
Burger Motorsport has been tuning car since 2007.... just saying. As for the guy that fu**ed up the engine in his Stinger, there is more to that story, it wasn't only JB4 he was using, as far as I know.
Before I choose the JB4 tune for my car, I did my homework and I been reading, follow for over 3 months all 3 big players in the game; RaceChip, JB4 and Lap3 on Stinger forum. Here is the link The Ultimate Kia Stinger Tuning Forum
Btw. here is the list of the fastest Stinger so far ;)
One nice thing about the JB4 that interests me is meth/water injection integration.
Also, fastest 1/4 time is AWD! Looks like once you start making more power we can actually take advantage of that extra traction. Thanks for posting that. Nice!
50jae
177
43
PA
Here is a drag race between the 2. Dyno shows more hp with the G70. Watch around 9 min mark for the second video. Definitely different tunes stock, at least in KDM cars.
Edit: I didn't see the other video posted above which is the same as my first link. The second video contains the dyno results at 9 min mark
Toddasaurus
831
673
93
Portland, OR
Found a small reference for a larger turbo in Korea.... specifically, this picture. No info, though.
Personally, I think a pair of GT2560R's would be perfect. Small/compact, ball bearings instead of journal bearings, oil/water cooled - bigger but still not too big.
joschneider
199
43
Las Vegas, NV
Just tried launch control today...and I couldn’t get it to work. All traction off, everything warmed up, and it let me rev past 3k with no launch control message at any point. What am I doing wrong? I feel like i must be missing something
Beefer
2,749
1,925
Richmond, VA
Traction control...press and hold the button until it’s all turned off. You cannot just press and let go. That just turns off half the nannies.
Obviously foot on brake while applying the gas.
NLJ
409
83
Do you have to go to park before you go to Sports or can you just go to Sports with the brakes depressed and turn off Traction?
I tried once too and it didn't engage and never tried again!
Beefer
2,749
1,925
Richmond, VA
You have to be in park to turn the nannies off...I think. I would have to try again.
Beefer
2,749
1,925
Richmond, VA
Also...not sure if too cold outside...or too hot prevents it.
joschneider
199
43
Las Vegas, NV
Just tried it and I didn’t have to be in park, was able to do 2 back to back runs like that. My issue was I didn’t have it all turned off and then I also didn’t have my foot ALL the way down on the brake. My fiancé was in the car with me so I’ll have to do a launch by myself but...wow! No wheel spin at all, it just goes. Def safe to add more power or tune for a higher launch rpm
scorp99cam
43
13
No Genesis Yet!
Just to confirm you have a USA G70 right? The dealer told me there was no launch control on USA cars. I’m pretty sure he was wrong, but I haven’t tried it out yet.
