Leaking Strut
C-130Geek
Pelzer, SC
I have a 2015 5.0 ultimate. The left front strut is leaking. Replacement is about $1,200.00 because of electronic dampening. Only available OEM and Hyundai now says item is discontinued. anyone else had a problem electronic strut and if so what did you do.
Jeez.....You could go passive and get the module to get rid of the check engine light. The module is pretty pricey but not as bad as 1200 smh.
I don't have a light yet still have a leaking strut with no replacement available.
I mean you can always ditch the active suspension and put a normal coil and strut in but doing so will give you a light which the module will cancel out.
I checked Suspension thread but couldn't find mention of a module. Do you have a P/N and/or installation?
