Locked Out
ASLAN
144
86
Genesis GV80
FYI. GV80 Prestige will lock the car when your key is inside if you lock from the remote app. Anyone else confirm this behavior?
Speeder
316
63
Quinton, NJ
Genesis GV80
Yes it will.
Mcc
Supporting Member
SUPPORTING MEMBER
3,563
911
Los Angeles
Genesis G90
So you are not really locked out as your title suggests since you can get back in the same way you locked it, through the remote app.
ASLAN
144
86
Genesis GV80
No. Sorry. You can. My phone was almost dead and I thought about the app to get in. And did. NFC card also did not work. Should have titled it you can lock your keys in your car! I did not think the tech would ever allow that.
tarhoosier
907
93
Charlotte
I have the app on phone for my wife so she can use it and in case of this situation (dead phone, locked out) she can use her phone and app. Same log in, same password, same car, different phone.
2021GCSGV80
195
43
Genesis GV80
I read somewhere but cannot find it now that if you use the app on the phone to lock the car that it overrides all keys and you must unlock it with the app to get in.
BillZ
90
Toronto
I had a near disaster with the suggestion that you can lock your key inside using the app. I was doing the April 14 update (having done the March one, I thought I was up to date). Leaving the car running (which you're told to due during the update process) in the driveway with the car unlocked didn't seem a great idea, so with the key in the car and the engine running, I used the app to lock the doors. Now you all should know that when the car is left idling in park, a 30 minute countdown starts before it automatically shuts off in the absence of any action from the driver (such as touching the brake pedal). I went out to check how the update was going by looking through the driver's window. It was still only about 60% and the countdown on the dash indicated the car would shut down in about 10 minutes. Now the doors are locked; so I tried using my wife's key. Nothing. I then tried to unlock using the app. After spinning for a couple of minutes, I received an email saying, "Sorry your request could not be processed". I tried again with the same result. So I called Connected Services for help. Absolutely useless. Then the car shut down. A minute later I tried my wife's key and it worked. Miraculously, it seems the update had completed seconds before the car turned off. Otherwise, I may have been left with a bricked infotainment system. Short story, DON'T LOCK THE KEY INSIDE USING THE APP DURING AN UPDATE. Presumably the system can't receive commands during the update process. It would be nice if Genesis had warned us about this.
joegr
2
342
63
It seems that so many forget that there is a mechanical key that they can use.
Mcc
Supporting Member
SUPPORTING MEMBER
3,563
911
Los Angeles
Genesis G90
No reason not to. It does check your fob battery charge any more than checking to see if you are a carrying a spare key.
I can lock my car with the key inside as long as I do it with my second fob. So it knows if you can lock it, then you can unlock it the same way.
m0pher
65
Genesis GV80
Had a weird related issue a couple of weeks ago. My garage called and said I needed to come down immediately because the GV80 was locked with the fob inside and they had no way of moving it. Thing is, I never used the app to lock it. I then tried to unlock it remotely via the app. I received a “success” confirmation and then when I refreshed the vehicle status a minute or so later, it was locked again. Did this for about 45 minutes before the car stayed unlocked. Bizarre.
joegr
2
342
63
It will relock fairly quickly if no one opens a door after it is unlocked.
jimmak
109
43
Genesis GV80
Wow lots of info and experiences. I haven't tried lately to get my phone as a key to work. I had no luck the first few times I tried. I can use the app...
The auto shutdown time is adjustable, mine is set at 30 minutes, if course that is no help if you're already locked out. Almost all features of the info system are disabled during the update, I imagine that is why the app didn't respond.
I've got a busy weekend coming up, next week, maybe I'll try to set my phone as a key and see if I can set up the NFC card they sent me a couple of months ago. :)
TonyD09
No Genesis Yet!
To setup the Card/ Phone as a key you must have both Key Fobs in the vehicle. And I think the card of or the phone in the NFC/Wireless charging pad. It should work then once you go the steps.
redneck
12
Genesis GV80
we get updates on our jaguar where they say to start the car to keep the voltage up as the updates take alot of battery power. i just put a battery charger on it & dont start it no big deal for the 1 hour it takes every year
redneck
12
Genesis GV80
yes most cars do this my ram trucks relocks in 15 seconds if you dont open a door
