Loss of Power
matpal
34
So I always thought my car was slower than what it should be (completely stock) and this was confirmed after driving a loner car of the exact same 3.3 AWD. My car just doesn't nearly have the same acceleration in any mode.
I remember reading one of these online magazines had their turbo disconnect and wonder if that could be my problem. I am kind of at odds with my service center from them cosmetically damaging the car the last 3 times it's been in, so I wanted to see if I could do a quick fix myself before hassling with them again.
Not being mechanically inclined at all, and not being able to find an engine diagram, are the turbos easy to visualize from either top or bottom? Best way to get to them?
Or has anyone else had this issue of missing power and has a different solution?
csu87
134
43
if youre not mechanically inclined, you might have some trouble finding the issue.
could be a loose hose causing a boost leak. start at the Blow Off Valves and work your way back from there.
Cashby
317
63
Pop your hood. Take a picture of the left side of the engine and right side. Follow the intakes (black boxs) We might be able to help if you post pictures. might be able to see a hose off.
