Low Beam Adjustment Maxed Out
Elwood4u
Minnesota
Hey all,
I've come across a few threads here regarding adjusting low beam which as been helpful. I've set the adjustment screw all the up (U >) however I still only get about 50 feet of visible light. I'm pretty sure its maxed as the gear turns freely and then abruptly stops once max is reached.
Any other thoughts in regards to raising drivers side low beam a few degrees more? 2013 base sedan.
Thanks.
Are you putting the regular halogens back in or did you change the bulb type to LED or HID?
