Low tech/Old school solution to DRL burning out
Aurally
21
Massachusetts
There is tons of discussions on how to ditch the 2357A filament lamp and use an LED instead on this forum. However, like some, I am concerned that the LED replacement still seems like a niche product, which on top of many things, require mods to prevent hyper-flashing, none which I find elegant. LEDs last almost forever, but the electronics that accompany it often fall way short. In addition, I can't tell if they are designed with on-off blinking in mind at all.
So, I decided on an "old school" solution, which is to keep the incandescent lamp and try to pro-long its life. I know some have lasted for years in my previous cars. Simplest way to me was to solder an 1 Ohm resistor in series. This drops the filament voltage by 10%, which according to charts I found on the web would predict an increase in lifetime by a factor of 2-5 times. Furthermore, with a cold resistance of around 0.6 Ohm for the lamp, this would also lower the inrush current to more than 1/2 the current amount. So far, my passenger side light failed twice right after I activated the blinkers, I am thinking the inrush current is the bigger culprit here. If this can make the bulb last 3-6 years, I would be happy.
Connecting the resistor in series is about the easiest electrical mod one can make, especially if one knows how to solder. I used a 25W resistor I had in my junk box:
19776
Worst case, standard wire nuts found in household wiring may do just fine.
Wired in the car, I am measuring a 1.9V drop across the resistor, which equates to just under 4W of heat in the resistor. Based on derating curves, this would predict a 50C temperature rise without any additional heat sinking. People use 6 Ohm in parallel for LED replacement, which consumes more than 20W, and I doubt all have them heat sinked to a metal surface. I would love to see any pictures of such a resistor burning through the wires in the light housing, I have yet to come across one. At 4W I think I will be fine leaving it dangling in the air inside the light fixture. Maybe I will check on it in a few months.
Finally, nobody likes dim lights. Here is a picture with one light modded so one can compare the difference:
19777
Not a fair test as the exposure may have overblown the whites in the picture. With my naked eye, I can say the difference is really minor, and it's only because I know which one I modded.
I don't wait to wait 6 years to prove out this mod before sharing it, but I think it's a good solution. Still, perform this mod at your own risk.
Aurally
21
Massachusetts
For those people who might be on the fence regarding overheating, I opened the driver's side light fixture this week to take a peek inside, everything still looks like the day I installed it.
Pedal Commander
