Maintec Variable Catback Exhaust Install
LindrelT
15
30
13
Houston, TX
I also ordered from Shark Racing... ordered 7/17 and was delivered today! Haven’t unboxed but nothing sticking out of the rather beat up box! I’m planning on a fixed wired switch rather than the remote setup provided. Thanks @Draco-REX for the write-up!
ephone1
209
170
43
West Michigan
Let us know what you think when it's installed. Are you going to have it done, or do it yourself?
LindrelT
15
30
13
Houston, TX
I’ll do it at home. Will take my time and do the vacuum connection and solenoid part under hood first. Got the parts as @Draco-REX suggested and will get the switch located and hooked up. Have a vacuum gauge to see that it is all working. Not sure about the route for the vacuum line going back. We’ve seen the underbody route along the gas line work. Through the cabin under door sills with the battery cable is a possibility also and keep it more protected. We’ll see... no rush as this is a good project while stuck at home for a while!
ephone1
209
170
43
West Michigan
I'm considering using this nylon stainless steel line and running outside. It's expensive, but it looks durable.
https://www.amazon.com/dp/B07JFPXHB...b3RMb2dDbGljaz10cnVl&th=1&tag=salsbloofnot-20
RonE_RRTX
The box arrived today. Quite beaten up - will see what things look like in about an hour.
ephone1
209
170
43
West Michigan
Mine should be here in the few days. Are you going to install it yourself?
RonE_RRTX
Yes. There is a DIY shop with lifts 10 minutes from my house.
RonE_RRTX
@Draco-REX - I completed the installation of the Maintec exhaust today. Did everything per your instructions (btw - great job). The valves are not opening. I tested everything prior to connecting the lines to the valve assembly. Getting vacuum when hitting the "on" button on the remote. The green light comes on. I did have to bend one of the valve assembly mounts back to the straight position as it was bent from shipping. How much force should be needed to move the actuator arm on the assemblies? Mine are pretty stiff. When the unit is turned, the arms do not move. I am assuming they should move inward towards the blue body of the assembly. Should I loosen anything on the arms? These look to be spring loaded, but really tight and would require quite a bit of force to move them. So, after a several hours of engine bay setup and then the installation of the exhaust. my car still sounds very meek. Help me please!!!
Draco-REX
186
43
Ohio
They should be very easy to move. I could move the connecting rod rapidly just by pinching with my thumb and forefinger. Try adjusting them again until they move freely.
RonE_RRTX
Thanks. I will try this later today.
LindrelT
15
30
13
Houston, TX
I haven't installed yet but just ran out in the garage with this check for you... I hooked up vacuum line and a tee to the valve. Sucking on the tube I could get to 13" and the valve was fully open. Not bad for a 66 year old who had COVID. I would use a vacuum garage and see that your setup under hood is all working with no vacuum with the solinoid valve in 'off' and 15" or so in 'on'. Then do the manual valve check like the pic. If 15" or so won't open it then something is bent and needs to be straightened. If all is well then a good line connection from to back and it should be good (and louder)!
RonE_RRTX
@LindrelT - Thanks, I will give it a try later today.
RonE_RRTX
@LindrelT and @Draco-REX - I found the issue. The valve that had the bent bracket is leaking. I disconnected the line at the T. Checked the vacuum there and it was good -
I reconnected it, started the car and got back under the exhaust. I hit the switch to activate the valve and could hear the leak -
The videos and some photos of the bent assembly have been sent to Shark Racing. Will see what they come back with.
Draco-REX
186
43
Ohio
Sorry to hear that. I hope they take care of you. At least you were able to pin point the fault.
RonE_RRTX
Update: Sam from Shark Racing is going to request a new valve assembly from Maintec and ship it to me for free. As I await the replacement part, should I consider "locking" my current valves in the "open" position??? I have yet to hear the exhaust system on my car! I am thinking of using metal zip ties or picture hanging wire.
Draco-REX
186
43
Ohio
I'd disconnect the bad valve and cap the line. Then I'd force that one open like you described. You'll still have control over the good valve so you can muffle it some if you want.
ephone1
209
170
43
West Michigan
I wish I could just buy a couple extra for later, in case they fail.
LindrelT
15
30
13
Houston, TX
Back on the project today... I'll try to highlight differences from @Draco-REX 's great write-up. I also bagged the remote switch unit that was included. I sourced this this one for under $30.
It is reasonably sealed and has 'on' and 'off' buttons and yes, it supports Homelink! I also got black vacuum tubing here.
I decided to tap the manifold vacuum after the check valve like this so even under boost the valves will work off the vacuum reservoir:
