toxicavenger70
- Aug 28, 2018
I recently took apart the map light assembly in my wifes car. Here are some things I thought I would share.
I was not able to remove the circuit board from the plastic housing. There are multiple tabs you have to push in to remove it. And I was to lazy to try. I would think if just wanted to replace bad LCD's for the map lights you can either desolder them from the circuit board or cut the wire and splice on new ones.
I hope this helps some one out.
