Mapnsoft has updated site for 2017-2018 Genesis Map Updates
Florida Alan
14
Fort Lauderdale, FL
Genesis G80 Sport
I understand the 2018 G80 VINs were added to the mnsoft-Genesis site today.
Looks like you are correct. I entered my vin today and it was recognized.
I got this message: "THIS VEHICLE IS CURRENTLY UP-TO-DATE OR NO UPDATE IS AVAILABLE."
I bought mine May 16, 2017 and thought I would need the update, but apparently not.
pmcjr
20
Florida
Florida Alan.....Alan, go to the mapnsoft Genesis site, log in, and click on "How to check your map version". The current version will be shown on the Setup>System Info Screen instruction. You can then check this in your car to see if the Map Version is what is shown in this how to screen. Perhaps there is not a new version for the 2018s yet, but you an check and see what you have compared to the website. I talked to someone at mapnsoft yesterday and this website is a little tricky to follow...at least it was for me. I was told the best way to check to see if there is an available update is to do what I described above. Also, they told me they think Genesis is only paying for one update a year ,ie, three over the three years comp period. If this is true, no need to keep checking. Wait till we're coming up to one year. That's what I did. Bought my 2017 in 12/2016 and had my first update Jan. 2, 2018 when I had it in for an oil change. But after reading the Installation Manual (that will also show the most current version on p. 2) I could have done it by ordering the SD card. I just didn't know what was involved. Good luck.
Rlink
Oklahoma
I have a 2018 that I purchased in October. It's current map version started with 10.41 and the map update I received today will bring it up to 10.47...
EdP
Supporting Member
SUPPORTING MEMBER
7,836
4,109
Parrish, FL
Bought mine Oct. 20 and got the latest with it. The Mapnsoft web page does not give the version, but gives the part number. Says mine is up to date part no G115P2 The version in the car is the same as yours 10.47.43.713.203.2
pmcjr
20
Florida
If you go to the mapnsoft/Genesis site and click on "How to Check Your Map Version", step 3 does give you the current map version for your vehicle. This is updated with each new mapnsoft version. You can then check this in your car to see if you are current. The current version is also shown in the Vehicle Installation Manual tab. So, you can get the version in addition to the part number.
Kurmudjon
81
16
Just installed map update to my 2017 G 80. Everything went as advertised except I lost my address book. Does still show previous destinations so maybe that's good enough. All radio stations remained intact.
Mcc
Supporting Member
SUPPORTING MEMBER
3,288
820
Los Angeles
Genesis G90
That’s the first I have heard of losing the address book. Has anyone else who has updated lost their address book. It’s kind of a drag since I think you have to enter the addresses in precisely the final order since there is no way to reorder, just to overwrite.
mcginnpm
Not sure which version you are installing. Mine said to insert the SD card and then start the motor (see attached). I didn't have to do anything after that.
(sorry...forgot to reply w/quote...this is for "pmcjr")
Kurmudjon
81
16
Apparently did not lose address book as I have found it in a new location. Unfortunately default is still "date" and not "name" although you can change to "name" but need to do every time you use. Think I will just use "past destinations" which are also by date.
Mcc
Supporting Member
SUPPORTING MEMBER
3,288
820
Los Angeles
Genesis G90
Glad to hear that the address book was not lost. I use the address book a lot but really on the first 10 or so. You have to figure out ahead of time which are you most use (or important) addresses and enter them first in order of importance. This way they will be always at the top of the address book list. For me that is easier than using previous destinations.
Kurmudjon
81
16
Yours must work differently than mine. When it sorts by date it lists the most recent entries first not the initial entries. So that would not work for me.
Mcc
Supporting Member
SUPPORTING MEMBER
3,288
820
Los Angeles
Genesis G90
Just add them in the reverse order. Add the most used or most important last so it will show up first. The basic idea is you need to make your list on paper ahead of time and then enter them in reverse order.
pmcjr
20
Florida
I just checked with Genesis Customer Care to find out if complementary map updates on 2017 G80s and later are once a year or every time Mapnsoft comes out with an update (which I understand should be twice a year). The answer is annually. So, three complementary updates during the three year period.
EdP
Supporting Member
SUPPORTING MEMBER
7,836
4,109
Parrish, FL
Good to know. My car came with the latest update so i'm good for four years. I have to get that last one in the last month I guess. Very few new roads being built in New England, most updates are POI.
Don88
♪If You're Ready (Come Go With Me)♫ Staple Singers
SUPPORTING MEMBER
409
117
43
Vancouver WA U.S.
The website now accepts my VIN and the Update will be here tomorrow! Then comes the scare! There is a statement in the Update Install directions.
"Warning: Preset radio stations and saved addresses may be deleted after update."
Sometime tomorrow it will be courage time.
pmcjr
20
Florida
Don88....how did it go?
Don88
SUPPORTING MEMBER
409
117
43
Vancouver WA U.S.
Just completed the Map update. All went smooth; just followed the easy directions and no problems. Just to be on the safe side, left the radio off and sat through the install. It takes about 15 minutes.
The update is a 32 GB SD that comes in a nice card booklet with installation instructions.
pmcjr
20
Florida
Don88...Thanks for the feedback I took mine to the dealer last month for the update. At the time, I didn't know about ordering the SD card from Mapnsoft and I hadn't seen the instructions. I thought there was more to it than that. For the next update, I'll order from Mapnsoft and do it myself. That seems to be what most people are doing.
Gold
Nanuet
My car was supposedly updated by the dealer. MapnSoft still from what I can see has the wrong information. My brother has lived in a new development for almost four years and it still has the streets wrong. On Route 202 in Pa the speed limits are wrong. Free yearly updates are supposed to be available on the 2017 G80 so why are they charging some people. None of this makes sense.
