Menu Frozen/Lag/Slowness
Gahaha
Recently it seems when navigating through the menu or media everything freezes for a few minutes. It seems like the display itself is running slow and/or frozen. Are there any ways to fix this? Restarting car doesn't seem to fix the issue.
PS Also seems certain controls like fan high or low/off/on will kick off the slowness or freezing, whereas remaining in media center doesn't.
2015 5.0
2015 5.0
You can try a reset of the system. There is a small hole in the front panel near the CD slot on the right. Push with a paperclip of ball point pen to reset
Unfortunately issue still remain, I wonder if it needs to clear cache or something.
You’d need to get into engineering mode and check these numbers.
How do I do that?
If you have the tech package and can get into engineering mode without using GDS, please let me know. I have spent several man-hours trying to crack the 4 number PIN, to no avail.
Ok to update everyone, I was able to fix the issue, costs me nothing. Downloaded update from Hyundai, put it on a USB and updated. Drove around for an hour or so and everything works.
