Mirror tap for radar detector
nodenwire
Yes to the ignition power wire so the radar detector turns on when the car is on. Do you need a picture of which wire is positive and which wire is ground?
Acpantera
39
Genesis G80 Sport
Might be better off running the wire tucked in the headliner to the A pillar then down to the fuse panel, use a fuse tap.
I put my detector in the lower left above the reg sticker, real tidy.
surprisinguy
72
NC
I have my V1 right above the mirror on the left - can still use the visor, but ended up having to run the power along the headliner, down the pillar and a fuse tap. Cant see it from outside the car.
WWIAFTM
22
23
No Genesis Yet!
I'm envisioning the lower left hand corner of the windshield as well. I also will need to rig my dash cam somewhere. :unsure:
Acpantera
39
Genesis G80 Sport
I think so, but you can tuck a wire across the top of the a pillar trim and down along the inside the door seal.
Melatonin
Dallas area, and beyond.
I inserted them in the back of the female connector.
So I inserted into slots 6 and 8 in the order you did. My detector does power up but, it doesn't turn off. I'm guessing pin 6 is not switched in vehicle as it is in yours? I'm saying this because the front of my rear view mirror has the button in a slightly different configuration. Would you be able to share where you found that diagram? Perhaps there's a slightly different version for my vehicle? Thanks.
