Mis-aimed headlights from the factory
Throat Yogurt
6MT Mafia
243
529
93
I'm right here.
Anyone else have this problem? I drove my car at night for the 2nd time since I got it two weeks ago, and noticed that the low-beam cut off was at about the level of oncoming car's roofs. Not surprisingly, I got flashed with high beams by 7 or 8 cars on the way home from work. Off to the dealer I go... :rolleyes:
Beefer
I’m faster
5,002
4,507
Richmond, VA
Hmmm...I thought they auto-adjust every time you start the car. Any sensors dirty?
Perhaps the levelers are off.
Odd that it’s both (or is it?)
surprisinguy
207
43
NC
You should be able to adjust them yourself - pretty sure anyway.
I can and have adjusted mine because they were too low
Throat Yogurt
6MT Mafia
243
529
93
I'm right here.
It's both. I've aimed headlights before, but never with auto leveling. Maybe I'll try and break things under the hood this weekend. (y)
GranPoppy
Genesis G90
I am having the same problem with my 2018 G90 (New car for me). The top of my low beam light only reach out about 50 feet. When I drive at night without high beams, it like driving into a dark hole. After pointing my headlight against a wall, my dealer says they are adjusted correctly. Seems like there should be a more scientific way to adjust. At night, there is no way to see anything without light more than 50 in front of you and if driving at 65 or 70, it gives you about a half second to react. Does anyone have any suggestions how to get my low beams to shoot our further?
pulsar
894
617
93
DFW, TX
Old school approach. There appear to be adjustment screws behind the headlights close to the fenders. Park your car on a level surface at nite, lights on and walk out 30 to 40 feet away. Squat down partially so your eyes are maybe 3 ft or so from the ground and see how the lights look? Blinding and too high or aimed to low? Use the adjustments screw to raise the headlight assembly a turn or two and repeat looking at the light 30 to 40 feet away. Raise them till your comfortable but the light is not directly in your eyes. When finished pull down close to a closed garage door or blank wall and see that both beams are at the same height. Go drive and test it. If your not flashed your probably good. I’ve used this method over the years just fine but YMMV. Not sure how self leveling works on our vehicles though.
GranPoppy
Genesis G90
So, after waiting two weeks for an appointment with another dealer, my headlight problem has been corrected. For others that may be struggling with to low or to high headlights, here is the solution from a dealer that took ownership and time to solve the problem.
"Found suspension height rod loose from mounting stud. Re-secured rod and lighting low beam now adjusts as designed and aimed properly." From another post regarding this same issue, this evidently is a leveling sensor for the automatic adjusting headlight on the G90. So it is possible for it to become detached from the mounting bracket which causes the headlight to move to and remained fix at their maximum high or low positions.
mrcleeaan
460
63
I always felt mine were aimed a little lower as they appeared to drop off at about 60 to 70 feet.
I can now say... Wow, what a big difference it has made after I adjusted them up just a bit. This is how they should have been from the factory.
I don't have a before picture but here's a night shot after the adjustment.
pulsar
894
617
93
DFW, TX
So you manually adjusted these and the auto leveling feature did not attempt to undo your changes?
kolme
"Diablo Rojo"
126
63
Texas
Low aimed headlights were a common issue in the DH Sedans. Many people, myself included, had to manually adjust the lights, so it seems plausible.
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
3,284
4,427
I may try this, actually. I've noticed my headlights seem to point just a little bit too low.
jfgenesis
2
i have been driving my genesis for 3000 miles now, and while i love the car, hate getting flashed by oncoming cars as if i have my high beams on.. i typically put them on to show them they werent, but that doesnt solve the problem of having to deal with that... so at the dealer now hoping they are aimed a bit too high maybe? i did love how bright they were for me though! can see things i have never seen before driving!
