tsquared
- Oct 9, 2019
- Location
- FL
Hey everyone, just wanted to share an experience I had with my 2015 5.0 the past couple of weeks. A few weeks ago I noticed under heavy acceleration that the car started to break up and cut power. After a couple of attempts at an italian tune up the problem got progressively worse and started to finally show some codes. I was receiving misfire codes for the passenger bank (1) for cylinders 1-3-5-7 so P0300 P0301 P0303 P0305 P0307. This would only happen under a heavy load and at higher RPM. After taking it to the dealer (which I used to be a service writer at) I brought it to the foreman who checked some things and thought it might be the high pressure fuel pump on that side. They were able to get the powertrain warranty to replace the pump ($1300). No dice. The car drove slightly better but still messed up. We did a full injector service and an induction service which smoothed it out a bit at idle but the high rpm miss was still there. While doing the pump which requires the metal high pressure fuel lines to be replaced the tech had the intake manifold off and was able to scope out the Catalytic converter. There appeared to be some damage. After a lengthy call with the warranty company they agreed to replace the cat ($1700). I can happily say my car is FIXED! I had searched these forums as well as the facebook groups and found people with similar issues that had replaced plugs coils injectors whole engines ect. Just wanted to share my experience since many dont follow up with solutions! Hopefully this will help someone in the future.
