honorable flea
- Nov 5, 2019
- Location
- the RVA
- Genesis G70
A story and a question....
SO i drive to work in the dark every morning, along many back roads. Headlights in AUTO mode as always. Was using the auto high beam assist to help avoid the hordes of deer that want to play ping pong off the bumper of the G70 this time of year, and I ended up catching up behind a slow poke in a pickup. Fine, I'll just follow him for a while. Figure I'll turn off my hi beams (even though they automatically turned off b/c they were in HBA mode). Pulled the left stick back, high beams turn on in flash to pass mode, OOPS, let go, high beams off... Push the stick forward, high beams turn on in manual mode, OOPS, pull back on stick, high beams cycle off, then on again since i'm in flash to pass mode again. OOPS. try it a few more times and eventually the poor guy in front of me pulls over, gets out of his car, inspects the back of his truck since he thinks i'm signaling him that his car is on fire or something, and then proceeds to glare at me. I mouth "i'm sorry". Feel like crap for confusing the poor guy.
anwyays... the question....
When high beams are on, but HBA is active (high beams sense light= turn off), is there a way to turn OFF high beams all together WITHOUT flashing your lights in any way?
I found in the High Beam section of the manual "• If the light switch is placed to the headlamp ON position, the High Beam Assist (HBA) will turn off and the low beam will be on continuously", but this would still flash your main lights since you have to cycle from AUTO to running lights to headlights.
thanks in advance
thanks in advance
