DTN
- Nov 22, 2025
- Genesis Model Year
- 2023
- Genesis G70
I decided to fix the two main annoyances with my 2023 GV70: the requirement for wired Android Auto and the lack of integrated high-speed charging without ugly dongles cluttering the console.
I wanted a factory-clean look with functionality that matches the premium interior. I engineered a solution that routes the data connection behind the dash for a hidden wireless dongle and replaces the visible port with a high-power charger.
The Build:
The Result:
Availability:
Since I've already done the engineering, testing, and fitment work, I can produce these for others.
Let me know if you have questions on the install process or want to grab one.
Prototyping
See through prototyping
Back of unit
Final version Installed
Clean installation
A new powerful USB-C PD port.
The Build:
- Design: Modeled a replacement housing in CAD to match the OEM clips and curvature perfectly.
- Fabrication: Iterated through several SLA resin prototypes to ensure durability and correct light diffusion (the blue ring matches the OEM ambient lighting).
- Power: Integrated a USB-C PD charging board. While rated for 65W, it delivers a consistent **30W fast charge** on the car's 12V rail.
The Result:
- Wireless AA: An AAWireless dongle is tucked behind the dash, connected to the data lines. Phone connects automatically upon entry.
- Clean Console: No visible wires. The port is now strictly for power.
Availability:
- Price: $70 per unit.
- Install: These are solidly engineered pop-in replacements. Installation from behind requires removal of 5 bolts, 2 pieces of trim and a few connectors.
Prototyping
Back of unit
Clean installation
