Mute Method.
2froggy
My recently acquired 2012 4.6l has the Lexicon radio and it seems to have a million options -but I don't see a simple "mute" button: is there one- or a way to quickly do it?
Hi, congrats on your new ride..
My ex VW had an easy to use Mute button..B U T nothing on my Genesis..
Incoming calls (BT) will override the radio/Nav if you have it..
I found it easy to turn the radio volume control (anti clockwise) to nearly zero with just a roll of my finger..
There is a power off by pressing the volume in or holding mode on the steering wheel for a few seconds. Since the nav and radio are separate, there is no mute
If you are listening to music via USB and your screen is showing your music list, you can simply press down on the DIS knob and music won't mute, but will pause. Hit again to unpause...........This is my half assed sorta helpful answer to someone......maybe...
Press the steering wheel Volume Button twice, this will mute radio etc.
Echo the reply 2 above - when playing a song on DVD on way home from airport tonight I pushed in the DIS button - paused it.
The steering wheel button Push""
did not work for me.. No worries..
On my 2012 5.0, pushing the "phone handset" button mutes the mic while on the call. Hiding it down for longer time hands it up. FYI
What does: "Hiding it down for longer time hands it up" mean? :confused:
I think he meant holding it down longer hangs it up. That's what it does on my Genny.
Yes, but then it defaults to the nav screen and stays there when you use "MODE" to turn the radio back on.
Yeah, I miss the dedicated mute button from the 2000 Buick I traded in on my 2012 4.6. I loved that mute button, because it preserves the exact volume as before.
On my 2012 I simply press down on the DIS knob to mute, and again to play.
For a CD, Jukebox, or streaming Bluetooth it pauses, not mutes. For XM or FM, no.
