My 12v 180w Charger port stopped working
Mr.Issaburn3r
Hello can someone point me in the right direction on why my car charger port stopped working. I only use it for led lights at night
Are both out? The one in the center console and at the dash. Did you check the fuses under the dash? Hopefully it’s just a simple fuse.
All my USB ports work it’s the lighter burner that’s out. And how do I know which fuse to reset
That door that you removed to access the fuses, look inside and it should have a legend of the fuses. If not, it will be in your owners manual. I'm guessing it is the one labeled "Power Outlet".
